Here I have a blown PowerBass Xa-3000D, Not exactly sure wats wrong but it played fine the other day and now its been skippin in and out of protection mode. Powers up just fine tho //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. These are some crazy amps!
I have the original box, bassknob and if i can find em, the mounting feet but im pretty sure most of the mounting feet places are stripped.
SPECS:
• 4 ohm Power : 1000W x 1
• 2 ohm Power : 2000W x 1
• 1 ohm Mono Power : 3000W x 1
• Strapped Power : 6200W
• Total Harmonic Distortion :
• Frequency Response : 10Hz - 400Hz
• S/N Ratio : >90 dB/W/M
• Damping Factor : >200
• Input Sensitivity : 0.3 - 8.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 50Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 45Hz
• Dimensions : 20.87" x 10.51" x 2.56"
• Dimensions : 530mm x 267mm x 65mm
Condition/Description/Other Information:
blown, the negative terminal for the speaker wire was stripped by previous owner so bigger one is needed to use. Gots scratches on the bottom from a previous install and a couple chips here and there, nothing to bad still looks good.
175 + shipping (PM me with zipcode for a quote)
will most likely be shipped by ups
SPECS:
