Sold FS: Powerbass XA-3000d $315+ship
allout13
1. Product:
Powerbass XA-3000d
2. Specs:
• 4 ohm Power : 1000W x 1
• 2 ohm Power : 2000W x 1
• 1 ohm Mono Power : 3000W x 1
• Strapped Power : 6200W
• Total Harmonic Distortion :
• Frequency Response : 10Hz - 400Hz
• S/N Ratio : >90 dB/W/M
• Damping Factor : >200
• Input Sensitivity : 0.3 - 8.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 50Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 45Hz
• Dimensions : 20.87" x 10.51" x 2.56"
• Dimensions : 530mm x 267mm x 65mm
3. Description/Condition:
Its used. It has a couple of light scratches on the top. The bottom has a couple of scratches as well. Its missing two of the screws for the speaker terminals (no big deal, just wire it as if it only had two terminals) Comes with bass knob and mounting feet. One of the mounting feet is a little bent, but its nothing hammer couldnt fix. function 10/10 aesthetics 8/10
4. Price:
$315 plus shipping
NO TRADES
5. Pictures:
nice amp. are you the original owner? any repair history?
thanks.
Im not the original owner, and I was told that it was only used for a couple of months but Im not certain. I could always take off the bottom and take pics of the guts if you were seriously interested though
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
just opened it up and it looks as though it definitely has been repaired before
Im contacting the guy that I bought it from, and Ill try and get more information about what has been repaired in the amp and by who.
wow, it must been a pretty bad blown:wow:
but you are definitely a real honest seller:thumbsup:
i think i'd have to pass after searching a little more info on this amp. best luck with your sale!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yeah. Im pretty pissed off. the guy I bought it from acted as if he had bought it brand new a couple of months before.
thanks anyways, man
If it werent for you, I probably wouldnt have caught this before I sold it to someone else //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
woah, blown MOSFET's. I bought my XA3000D for 400 and I need another one. I saw this and I almost couldn't pass it up....until now. Good luck.
should the amp be able to work at all with this problem?
is it an expensive fix?
should the amp be able to work at all with this problem? is it an expensive fix?
after a good fix, by someone like db-r, it should work just fine. but if it's been abused real bad before, some other components might be at the edge of failing. but you can't detect n' replace them since they are still in working condition. and they won't last in the long run. this was exactly what happened to my niche:(
I emailed the seller, and powerbass. maybe there is still warranty on it. If not Ill have to find someone who can repair it, or maybe I could try myself. The kid even had it hooked up for me to hear before I bought it. fml
allout13
allout13
Georgia
allout13
