Sold FS:PioneerDEH-P8500MP CD/WMA/MP3 Player-OEL Display w/Motorized Dual Display,AUXinput
bizflawless
How Fly
sup fellas, i got for sale a PioneerDEH-P8500MP CD/WMA/MP3 Player-OEL Display w/Motorized Dual Display, an also included is the remote and optional aux. works like a charm, in very new condition GUARANTEED, minor little bitty scraches around the rob but u cant even see those....retails for about $359.95, im letting it go for $240 shipped, obo
"][/url]
"][/url]
this is what i found for description and specs
Prepare to be amazed! At first glance, the DEHP-8500MP appears to be a sleek, no-frills CD player. With a touch of a button, the brushed aluminum face slides down to reveal a second face! Best of all, the second face features Pioneer's cutting edge Organic EL Display. The large secondary face's high-res display will amaze you with its full motion animated 3D graphics. There are even screensavers built-in! Pioneer’s legendary Supertuner III ensures top-notch radio reception and features 24-station presets. CD playback is also cutting edge: AGC (Automatic Gain Control) ensures optimal CD tracking performance and playback is compatible with Digital Audio CD-R and CD-RW (when disc is finalized), as well as MP3 and WMA files. The CD section also features disc-title memory and CD-text decoder. The DEH-P8500MP uses Pioneer’s IP-Bus system for seamless interfacing with optional multi-disc changers, voice commander controllers, and TV tuners. If you plan on using this receiver to power a set of speakers, Pioneer’s exclusive MOSFET50 amplifier will amaze you with its power output and performance. A low-pass crossover with 18dB/octave slope is also built-in for the ultimate in upgrade flexibility. Pioneer’s exclusive EEQ circuitry allows for quick adjustment to the five factory and two user defined EQ presets. Pioneer’s Automatic Sound Levelizer reduces the effects of road noise so you’ll hear nothing but sweet tunes from your stereo. Comes complete with wireless remote.
Features:
Dual Motorized Detachable Faceplate
MOSFET 50W x 4 (max)
XM Radio Ready
Credit Card Sized Remote
Pop-Up Rotary Volume Control
EEQ Performance Chip
3-Band Parametric Equalizer (Adjustable Level, Frequency, and Q Factor)
Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful,
Natural, Vocal, Flat, Custom 1, and Custom 2)
Source Custom EQ Memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front and Rear
Three 4-Volt RCA Preouts (Front, Rear, and Sub)
Front/Rear High-Pass Filter (50/80/125Hz, 12dB/oct)
Selectable Low-Pass Filter (50/80/125Hz, 18dB/oct)
Sub-Out Level (-12dB to +12dB) with Phase Control
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
Organic EL Display (128 x 33 pixel)
Full-motion 3D graphic animations including 2 screensavers (Dolphins, Racing)
2 Level Meters and 4 background animations
Clock display and off (text-only) modes
16-character text display with Adjustable brightness level
Cellular Mute Capability (CD-CM1 required)
Compact Disc: Track Scan/Pause/Repeat/Random Play
Audible Fast forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text and ID3 Tag Capability
MP3 / WMA CD-R Playback
3-beam laser pick-up with AGC (Automatic Gain Control)
1-bit D/A Converter with 8x oversampling
Anti-shock mechanism
Radio: Supertuner III
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
MP3 Player SpecificationsAnti Theft: Removable Faceplate
Preamp Outputs: 3 sets
Preamp Output Voltage: 4 volts
CD Changer Controls: yes
Remote Control: yes
RMS Power: 20W x 4
Peak Power: 50W x 4
CD Frequency Response: 5-20,000 Hz
FM Mono Sensitivity: 10 dBf
CD Signal-to-Noise Ratio: 94 dB
Amp Total Harmonic Distortion: n/a
sold!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bizflawless
How Fly
bizflawless
Houstatlantavegas/Mars
bizflawless
