Sold FS orion mtx rockford fosgate pioneer amps
hustlemanlv
I have servaral amps for sale
Orion HCCA 225R with plugs $150 OBO //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2 x 25W @ 4 ohms
2 x 50W @ 2 ohms
2 x 200W @ ½ ohm
1 x 400W @ 1 ohm bridged
Fuse: 2 x 20A
Dimensions: 12" x 10.25" x 2.25" (30.5cm x 26cm x 5.7cm)
works perfect
Rockford Fosgate Punch P1200.2 $475 OBO:eek:
In like new condition works perfect comes with bass knob
P1200.2
1200 Watt 2-Channel Amplifier
The P1200.2 is Rockford Fosgate's most powerful Punch amplifier and can easily support a wide variety of subwoofer configurations. Massive PUNCH power is the Rockford Fosgate way! For best performance a capacitor is strongly recommended.
MSRP $899.99
Description Value
CEA-2006 Compliant CEA-2006 Guidelines
Number of Channels 2
Rated Power
continuous power 300W x 2 @ 4-Ohms RMS
600W x 2 @ 2-Ohms RMS
1200W x 1 @ 4-Ohms bridged RMS
Total Power
total sum of 'rated power' 1200 Watts
Bridgeable Yes
Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Punch Bass EQ (included with cable)
Visual Indicators Power On
Signal Level
Thermal Status
Speaker Protection
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 16.6 Lbs.
(7.5 Kg.)
Dimensions (HxWxL) 2.1 x 11 x 17.7 (in)
5.3 x 27.9 x 44.9 (cm)
MTX BLue Thunder PRO 75x2 $145 obo:fro:
Output Power at 12.5V:
2 x 37.5W @ 4 ohms (
2 x 75W @ 2 ohms (
1 x 150W @ 4 ohms bridged (
S/N Ratio: >110dBA
Damping Factor: >200
Freq. Response: 20Hz ∼ 20kHz (±0.25dB)
Fuse: 40A
good condition works 100%
Prodigy:naughty:
4 X 50 at 4 ohm watt amp with built in cross overs
$ 75 shipped
C4 ( copy of an older Lighting audio design)//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
CPA-5004
MODEL:
CPA-5004
1200WATTS MAX PEAK POWER
40WATTSx2CH(FRONT)& 85WATTSx2CH(REAR)RMS POWER
@0. 05%THD FROM 20HZ-20KHZ INTO 4 OHMS
75WATTSx2CH (FRONT)& 175WATTSx2CH(REAR) RMS POWER 2OHMS
DIMENSION(LxHxD): 12 3/4”x2 1/2”x9 3/4”
Real power here has 75 amps of fuse on the back
$ 125 OBO
hustlemanlv
hustlemanlv
las vegas
hustlemanlv
