I ran into some issues with money and need this gone ASAP.
Its never been installed, but has bumps and bruises here and there from being moved around. I have the manual, bass knob, plug, all the cords and install parts. Its the same thing as an Audiocontrol.
Specs:
$65 shipped/OBO.
Specs:
Pics:# Extends Perceived Bass Frequency Response# Generate extended bass response in systems without subwoofers, or compensate for missing lower octave bass response in systems with subwoofer solutions that lack good low frequency extension
# Wired remote included
# Buffered input with clip indicator and adjustable input/output controls ensure good level matching to system, and support up to 5V output signal
# System is transparent (no effect on signal pass-through) when effect set to zero
# Power, Clip LEDs
# Adjustable Intensity
# Adjustable Output
# Adjustable Input
# Adjustable Frequency: 60 / 80 Hz
# Crossover On / Off Switch
# 1 Pair RCA Inputs
# 1 Pair RCA Outputs
# Frequency: 20 Hz - 20 kHz
# Signal-to-Noise Ratio: >85 dB
# Seperation: 65 dB @ 1 kHz
# Crossover: 100 Hz, 24 dB/Oct. (Defeatable)
# Input Sensitivity: 300mV - 3V
# Output Level: 300mV - 5V
# Dimensions: 5.9" L x 4.53" W x 1.18"H
$65 shipped/OBO.
