Sold fs: orion hcca 275g4(3) and 8 directed 15's
mrwigglezdj
bass boxing champ XD
up forsale today is 3 mint condition 100% operational and 95% looking orion hcca 275g4's, with plugs no damage to amps all are in great shape and work 100%, then 8 directed compX subs dual 4ohms, in great shape and well taken care of,
there all being sold because my buddie is going to do a complete memphis system in his truck for the local shop. i will stand behind all items 100% since i helped him install them and made sure all works as described as we removed them.
i dont have the info on the amps but im sure that info can be found at realm's amp guts ect
looking to get 575 out of each amp shipped in the lower 48 (discount if all 3 go at once)
and looking to get 145 out of each sub shipped in the lower 48 ( and can possibly do better if more than 2 are bought at once)
Power ratings at 12V and 0.1% THD:
2 x 75W @ 4 ohms
2 x 150W @ 2 ohm
2 x 300W @ 1 ohm
2 x 600W @ ½ ohm
1 x 300W @ 4 ohm bridged
1 x 600W @ 2 ohm bridged
1 x 1200W @ 1 ohm bridged
THD: 0.1% (4 ohms, 20Hz ∼ 20kHz)
S/N Ratio: 100dB
Damping Factor: >400
Freq. Response: 20Hz ∼ 20kHz (±0.25dB)
Linear Bandwidth: 6Hz ∼ 50kHz (±3dB)
Fuse: 6 x 30A
Dimensions: 25" x 10.25" x 2.25" (63.5cm x 26cm x 5.7cm)
Manufactured in 2000. G4 stands for 4th Generation.
yes, we just cut the wires close to the plugs so we wouldnt have to wrestle with undoing all 3 amps, just a simple snip and they were out. but the plugs were damaged? if thats what youre wondering
No i was just wondering if there was enough wire on the power plugs to even still use the plugs. Looks like there wouldnt be much room by the time you stripped the wire and then went to solder. Maybe its just the pics?
? the wire in the plugs isnt to reuse, you install your own wire , simply unscrew the bottom of the plug and the wire will come out and insert your new wire and screw back down and its done
on those plugs there are set screws so you can put any wire in them... no soldering required
ok i will be heading to daytona area tommrow for the weekend, so i can bring any item with me, if i hand deliver the amps i will drop the price to 500 a pice deliverd and if i deliver the subs i will drop the price to 115 each.... if you want either or any let me know tonight or eairly tommrow am as im leaveing by 11am my time
mrwigglezdj
mrwigglezdj
milton fla
mrwigglezdj
