Orion HCCA 225r
Rated at 12v:
2 x 25W @ 4 ohms
2 x 50W @ 2 ohms
2 x 200W @ ½ ohm
1 x 400W @ 1 ohm bridged
Fairly underrated - should push around 600w @ 1ohm bridged @ ~13v, and should be able to take more than 14v.
No problems mechanically. The crossover, gain, and phase switches and knobs all work as they should. No problems from what I can tell with the RCA inputs. All 4 mounting holes are similarly marred (see pictures), but shouldn't be a problem if you use washers. I have taken pictures of places where the color has come off (see pictures). However, it is in great condition for its age, and looks flawless (minus the mounting holes) from a few feet away. Comes with plugs and fuses as pictured.
Also, this is the version that says "Made In U.S.A." on the PCB on the inside, as opposed to the "Made in Korea" version.
$140 + Shipping
Orion HCCA 225r
Rated at 12v:
2 x 25W @ 4 ohms
2 x 50W @ 2 ohms
2 x 200W @ ½ ohm
$140 + Shipping
