Sold FS or FT: CDT EF-80 8" SUBS ((PAIR)
fast306stang
I have a pair of CDT 8's, the model number is EF-80. I'm the 2nd owner, the first said he used them for a couple of weeks and I've used them for about an hour. They look brand new and I will post pictures later, I just wanted to get the ad up for now. Specs are:
Power handling: 200 watt RMS Max 400 watt
Diameter: 8" (200mm)
Sensitivity: 87.1 dB
Power Handling: 200 WRMS (400W Pk)
Frequency Response: 10 ~ 400 Hz
Nominal Impedance: 4 Ohms
SVC Voice Coil Diameter: 1.5" (39mm)
Peak Xmax: 10mm
Magnet Weight: 30 Oz
Nice subs, but I've decided to use a single 10" so I don't have a use for these anymore.
$90 shipped for both, or $100 picked up---I have a super nice box I will give you if local pick up, hence the extra 10 bucks.
Will consider interesting trades...I could use another set of components, coaxes, etc. No junk and no wire please. Thanks and LMK what ya got...
Trade you an IDQ 10" V2 for them....
I'm interested. Can you send pics and details to silver98gt at hotmail dot com? I may trade both 8's and some boot for both of your idq's if you would be interested in that as well. That would get me down to a one ohm load which is what I'd like to do ideally. Thanks!
75? What's the mounting depth?
Mounting depth is 4.00 inches, cutout diameter is 7 1/4", and the outer diameter is 8 1/4".
SPECS:
Peak Xmax: 10mm
Thiele-Small Parameters can be found here: http://www.cdtaudio.com/pdf/EF-80%20specs%20parameters.pdf
I can do 80 shipped and I accept Paypal as well.
The reason I don't have pics yet is because they are mounted inside the box and it's a PITA to take them out. So I will use the pics from when I bought them--those are the ones that are posted already--I will take pics with them in the box tomorrow--NM, I will take them and do it now, it's almost 1am and I have nothing else to do, pics in a few...
Hello There/
I'd love to get these,for my Doors,in my Stang,but I know they just wouldn't go even w/a Build Out w/Steel Flat Stock/:(/:crap:..
A couple of Kicker ZR/240's or ZX/460's,Bidged 4/Ohm would give some *Nice UpFront Bass*/:D.Oh Yeahhh!
So I have to look for 4/Ohm,Shallow Mount Subs....Good Luck,though.
Regards/
Raymond
Those are them. In a sealed enclosure I bought them in. Took them out of the box and they are also in VERY good condition. Not a mark on the cone/basket/magnet.
fast306stang
fast306stang
Byron, Ga
fast306stang
