Sold FS: Nightshade Pole Plugs (Aluminum)
sundownz
Pro Seller
Supporting Vendor
1. Product:
2. Specs:
Stalk = 75mm long / ~33mm wide
Cap = ~71mm across / 15mm high
3. Description/Condition:
New pole plugs - made in the USA down the road from us in Troutman from solid aluminum.
Designed to direct air flow from the woofer cone motion behind the former for enhanced cooling vs. a pole vent.
These are also a big chunk of aluminum so they also act as a heat-sink.
Please check fitment yourself... will fit quite a few motors but not all motors. Will *not* fit first production run of NS motors, but will fit all later runs. I have used them in TC-9 motors and a few others as well myself.
4. Price:
$15 each + Shipping
6. Pictures:
these will make ur sub handle about another 400-500 rms daily. it forces air in the coil gap cooling it, plus wicks heat from the pole.
wont touch the dust cap look at the one i machined for ez streets hc it sits 1" high off the pole. these work great. just make sure ur dustcap is glued down good with the increase in pressure.
cut ur dust cap off,drop one of these in with lil glue, glue down new dust cap and will handle moooore powar....
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
