Nakamichi CD-400 High Performance/Amazing SQ In-dash CD Player/Receiver
Used, but everything works great! 9/10 Cosmetically. 10/10 Functionally.
CD-400 PDF Brochure
This revolutionary head unit represents a radical departure from the industry norm as it delivers true audiophile-sound quality.
The CD-400 incorporates state-of-the-art 24-bit digital-to-analog converters – an advanced technology application unheard of before in the mid-price range. The result – audibly superior musical reproduction!
To complement the ultimate in digital-to-analog conversion accuracy, a high-resolution preamplifier circuit topology was developed to achieve ultra low-noise and distortion levels and a highly linear signal transmission to the powerful and dynamic 47 W x 4 channel power amplifier. Additionally, triple-band tone controls, a Nakamichi tradition, are included to allow for fine-tuning the bass, midrange and high frequency ranges - essential for the corrective compensation of the poor acoustics in automobile interiors or source program material.
The unit's extraordinary mechanics and electronics are combined with an equally refined cosmetic design. Understated, yet sophisticated, CD-400 will grace the dashboard of any automobile in which it is fitted. The color of the front panel illumination is user-selectable to best match the color scheme of the automobiles' dash. On the LCD display, green or amber is selectable as are the units illuminated push buttons, allowing for four different color combinations.
Here are some specs..
Amplifier Section
Maximum Power Output 47 W x 4 (4 ohms)
Frequency Response 15 - 30,000 Hz ± 1 dB
Total Harmonic Distortion 0.1% (4 ohms, 1 kHz, 3 W x 4)
AUX Input Level / Impedance 1 V / 50 kohms
Output Level 4 V
Tone Controls
Bass 100 Hz ±11 dB
Midrange 1 kHz ±11 dB
Treble 10 kHz ±11 dB
Loudness 20 Hz + 14 dB (Volume level 20)
FM Tuner Section
Frequency Range
U.S.A. 87.5 - 107.9 MHz in 200-kHz steps
Other Area 87.5 - 108.0 MHz in 50 kHz steps
Sensitivity 15 dBf (IHF)
Signal-to-Noise Ratio 60 dB (Mono)
Stereo Separation 35 dB
Antenna Input 75 ohms (Unbalanced)
AM Tuner Section
Frequency Range
U.S.A. 530 - 1,710 kHz in 10 kHz steps
Other Area 531 - 1,602 kHz in 9 kHz steps
Sensitivity 32 dBµ
Signal-to-Noise Ratio 45 dB
CD Player Section
System Compact Disc Digital Audio
Error Correction CIRC Principle
Sampling Frequency 44.1 kHz
D/A Converter Type 24-bit converter
Frequency Response 20 - 20,000 Hz
Signal-to-Noise Ratio Better than 100 dB
Dynamic Range Better than 90 dB
Total Harmonic Distortion 0.005% (1 kHz)
General
Power Source 14.4 V DC, negative ground
(10.8 - 15.6 V allowable)
Current Consumption 9.0 A (At rated power output)
Installation Dimensions* 178 (W) x 50 (H) x 158 (D) mm
7 (W) x 1-15/16 (H) x 6-1/4 (D) inches
Outer Dimensions* 178 (W) x 50 (H) x 170 (D) mm
7 (W) x 1-15/16 (H) x 6-11/16 (D) inches
Mass Approx. 1.5 kg / 3 lbs 5 oz
$175 Shipped.
New price: $150 shipped!
Tracking & Insurance will be included in above price.
My phone camera is not very good, but here are some pictures. The head unit looks a lot better in person.
CD-400 PDF Brochure
Amplifier Section
Output Level 4 V
Tone Controls
Bass 100 Hz ±11 dB
FM Tuner Section
Frequency Range
AM Tuner Section
Frequency Range
Sensitivity 32 dBµ
CD Player Section
General
$175 Shipped.
