I have this refurb unit directly from mtx. I dont need it. I also have the External Bass Control knob which lets you control the bass on the amp. The ebc was used for about 1.75 years then has been sitting in my closet since spring 2004. EBC looks new.
Asking $250.
Specs:
Specifications
RMS Power 12.5 VDC
Input
Low Level Input
Crossover(s)
Hi Pass @ 85Hz - Front/Rear, Fixed, Defeatable
Low Pass @ 85Hz - Sub Channel Fixed
Thunder EQ
EBC2 Port
2 Ohm Load 320 w x 1
70 w x 4
4 Ohm Load 160 w x 1
35 w x 4
Bridged 4 Ohm Load 140 w x 2
Dynamic Power 14.4 VDC
2 Ohm Load 490 w x 1
100 w x 4
4 Ohm Load 245 w x 1
50 w x 4
Bridged 4 Ohm Load 200 w x 2
Dimensions (with ISO Feet)
15.6" x 9.75" x 2.1"
39.7cm x 24.8cm x 5.3cm
http://www.mtx.com/caraudio/archive/2004amps/thunder895.cfm
Asking $250.
Specs:
Specifications
RMS Power 12.5 VDC
Input
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
70 w x 4
35 w x 4
100 w x 4
50 w x 4
