FS: MTX TA92001 - $600 OBO
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
This amp is in good shape - has been in to MTX for repair and they certify it to be working properly. On my test bench the power supply makes a small high pitch noise above 14.2v DC input - MTX says this is not a problem (noise comes from the amp not through your speaker).
# Amplifier Class D
# Number of Channels 1 - Mono
# RMS Power (4 ohms) 1000 watts x 1 channel
# RMS Power (2 ohms) 2000 watts x 1 channel
# RMS Power (1 ohm) 3000 watts x 1 channel
# Peak Power Output 6000 watts x 1 channel
# Minimum Impedance Unbridged 1 ohm
# THD at Rated RMS Power 0.5%
# Speaker Level Inputs Yes
# Preamp Outputs Yes - 1 pair
# Built-in Crossover Low-pass (LP)
# Low-Pass Crossover Frequency 40 - 200 Hz
# Subsonic Filter 20 - 50 Hz
# Signal-to-Noise Ratio 65 dB
# Bass Boost -12 - 12 dB
# Bass/Gain Remote Yes
# CEA-2006 Compliant
# Strappable with Another TA92001
# Prizm EFX: Selectable Lighting Color, or Pusate to Beat
# Power and Protection LEDs
# Parametric Bass Control: o -12 - +12 dB Bass Control o Variable Bass Control Frequency: 30 - 80 Hz o Variable Bass Control Q: 0.5 - 4.0
# Onboard Crossover: LP (40 - 200 Hz), Sub (20 - 50 Hz)
# Phase Control: Built in
# Semi Unregulated MOSFET Power Supply
# High or Low-level Input
# Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
# 0 Gauge Power Connectors with Built-In 4 Gauge Capacitor Terminals
# Wired Bass Remote Control Included
# Frequency Response: 20 Hz - 200 Hz
# Dimensions: 24-11/16" L x 9-5/8" W x 2-1/2" H
# Fan Cooled Yes
# Amplifier Class D
# Fan Cooled Yes
