Sold Fs:mtx Jackhammer, Fosgate, Scosche,kenwood,bazooka
brmcm15
Oh lawdy!
2 - 12" - MTX JACKHAMMERS
decent subs, had them for almost half a year now and had no problems with them. I only had them powered to about 240 watts and they gave me a little brain shaking once in a while.
$60 + shipping O.B.O each.
Kenwood KAC-648S
Never really used this amp, got it from my uncle along of the fosgate.
specs from amp guts -
Output Power at 14.4V:
4 x 25W @ 4 ohms (0.08% THD - 20Hz-20kHz)
4 x 35W @ 2 ohms (0.8% THD - 1kHz)
2 x 70W @ 4 ohms bridged (0.8% THD - 1kHz)
Freq. Response: 10Hz - 45kHz (+0,-1dB)
S/N Ratio: 100 dB
Current Consumption (1 kHz, 10% THD): 22A
Fuse: 25A
Dimensions: 10.25" x 8.25" x 2.25" (26cm x 20.9cm x 5.7cm)
Weight: 6.6 lb. (3 kg.)
$45 O.B.O
Rockford Fosgate
missing some screws, end caps and center symbol but still works
specs -
- stereo, bridged mono or Tri-Way output
- 75 watts x 2 at 2 ohms
- 150 watts x 1 in bridged mode
- MOSFET power supply and output devices
- 80 Hz low-pass crossover, 12 dB/octave
- 120 Hz High pass
- 0/6/12 dB selectable bass boost at 45Hz
$30 O.B.O
And Last I have some wires and Accessories
10 Ga. Red Rockford Fosgate Power/Ground Wire with fuse holder and Black ground wire (ground - 3ft. and red 12ft.)
idk, say $20 O.B.O
8 Ga. Blue Scosche Power/Ground Wire (strands, longest lenght is 8ft 10in and one strand has a fuse holder )
^say about the same price as the R/F wires.
Scosche RCAs
cant tell if they are twisted or not cant tell
$10 O.B.O
Streetwires Power Distribution Block
one screw missing on the (4) 8 ga. part
(1) 4ga. input and (4) 8 ga. out
$7 O.B.O
pm me about any questions or offers!
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
Louisiana_CRX
