Sold FS: MTX Blue Thunder PRO150x2 ... fantastic old school 2 channel amps
MTX Blue Thunder PRO150X2 Amplifier
Specifications
RMS Power measured at 12.5 Volts DC:
75 watts x 2 into a 4 ohm load with less than 0.05% THD+N
150 watts x 2 into a 2 ohm load with less than 0.1% THD+N
300 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
120 watts x 2 into a 4 ohm load
212 watts x 2 into a 2 ohm load
425 watts bridged into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover
Variable 40Hz to 175Hz
12-18dB/Octave
HP or LP configurable
Dimensions
9" x 9" x 2" (22.8cm x 22.8cm x 5cm)
10-1/4 Wide Including IsoFeet (26cm)
PICTURES
One of the amps has a few scuffs on the front, the other is basically mint.
______________________________________
i have two of those, hopefully would want $60 shipped for each, or $100 shipped for the pair if shipped to the same location. they're in the condition i got them in, which was straight from the refurb factory, some small blemishes on the case but otherwise working perfectly.
I used to have two of these amps as well. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Very solid performers (i still have a blue thunder 5 channel that is going to be for sale eventually)
Bump
twoohfour
okay
twoohfour
Where you live (Ex. Los Angeles, CA)
tommyk90
