1500 watts at 2 ohms...
300 + shipping or pickup. used 1 month w/ low gain...has remote gain control, box and birth sheet+manual. mint condition
pm me
specs from : MTXAUDIO.COM
This amplifier is the one with the most teeth. It's got it all. Adaptive Class D Technology, for high power in a small package. Anyone can make a high power amplifier in a big package. But it takes smarts and careful engineering to produce big power in a small footprint. Adaptive Class D Technology is how we make this amplifier so efficient at producing power. The crossover is low pass, variable from 40Hz to 200Hz. And, we've even built in our compression circuit, to protect your woofers at high SPL levels. Add in the EBC2 and the Thunder EQ and this is one amp to be feared.
Download Owner's Manual in PDF form.
Specifications
RMS Power 12.5 VDC Input
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Compression Circuitry
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
2 Ohm Load 1000 w x 1
4 Ohm Load 500 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 1500 w x 1
4 Ohm Load 750 w x 1
Dimensions (with ISO Feet)
17.8" x 9.75" x 2.1"
45.3cm x 24.8cm x 5.3cm
pm me
Specifications
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
