New Monitor 1 amplifier, Mk 4.70 4 channels, Underrated output, very clean, no internal crossovers, built in Modesto, Ca by ARPA, same Mfg. as Zapco and Arc Audio, excellent SQ amp, perfect for an active front stage setup
Output Power (RMS)
Stereo @ 4 Ohm 70x4 Watts
Stereo @ 2 Ohm 100x2 Watts
Mono @ 4 Ohm 200x2 Watts
THD + Noise
4 Ohm 0.04%
2 Ohm 0.08%
Bandwidth: 5Hz-75kHz
Efficiency: 61%
S/N Ratio >100dB
Seperation >60dB
Damping (4 Ohm) >450
Input Type Isolated RCA
Input Sensitivity 200mV-2V
Input Impedance 10K Ohms
Minimum Load (Stereo) 2 Ohm
Idle Current 1.2 Amp
Dimensions 13.25"x9"x2"
175.00 Shipped
Output Power (RMS)
THD + Noise
4 Ohm 0.04%
2 Ohm 0.08%
Efficiency: 61%
S/N Ratio >100dB
Seperation >60dB
175.00 Shipped
