I have for sale a white Mmats d300hc, modified from Mmats, and then by Sergey Kliplin of KB audio... the board in it is about 2 years old.
Unlike every other modded d300hc, this one has a new protection circuit, that will protect the amplifier as good as the original one from the factory, but still gives the modded advantage, of running .7 ohm for burps and daily use without any issues..
This amplfier has been tested by Loyd Lowry, with RMS reading equipment, to do 2100 watts into .8 nominal (1.2 actual) @ 13.0 volts. It also does 1850 watts into the same loads, with 12.0 volts
amp will also do 1700+ watts @ 2 ohms per this review:
http://www.carsound.com/review_archive/amps/d300hc.html
Comes with the standard Linkwitz 24 db / octave x-over, and accepts 2ga power / ground.....
This amp is not real pretty, so if you're looking for a showcase amp, this isn't it. Case has several scratches, and it has a fairly large cap hot glued to the side of it as part of the mod.
if you want a rock solid beat your brains out amplifier, for a mean *** daily or competition system, look no further...I have run this amp on a single XXX 18 and it pounds the heck out of it. It is currently running on (4) Avalanche 15's.
I am selling, because I just ordered a Lanzar OPTI4000D.
I have references and over 1000 posts on the SIN forum (id is BKOLFO4), and 100% pos feedback on ebay (id is MY55CHEVY).
Asking $290 shipped.
Post any questions to this thread please.
Thanks!
Brian
Thanks!
Brian
