I have a ma audio hk-802sx and a ma audio hk-4000d forsale.Both are modded to take more voltage witch means more output power and you can use lower ohm subs than the companys specs.The hk-802sx i need $350 shipped and the hk-4000 $400 shipped.All specs are curved a bit because of the mods and the numbers are higher and with more votage they will also get higher.The hk-4000d can do a 1 ohm or somewhat lower.Some specs:
HK-802SX:
4400W RMS 2-Channel High Current Amplifier
500W RMS x 2 @ 4 Ohms Stereo
800W RMS x 2 @ 2 Ohms Stereo
1400W RMS x 2 @ 1 Ohm Stereo
2200W RMS x 2 @ 0.5 Ohm Stereo
4400W RMS x 1 @ 1 Ohm Bridged
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
Quiet Fan Cooling System
High Quality Power & Protection LED’s
Thermal / Short / Overload Protection Circuitry
0-18 dB Variable Bass Boost
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
Remote Bass Control
THD @ 4 Ohm
THD @ 2 Ohm
THD @ 1 Ohm
S/N Ratio: >90dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
Input Voltage Range: 200mV - 8V
Input Impedance: 10k Ohms
Dimensions: 2.7" H x 12.4" W x 27.3" L
HK-4000D:
RMS Power @ 14.4V: 50W x 1 @ 4 Ohm, 3600W x 1 @ 2 Ohm
RMS Power @ 17.0V: 75W @ 4 Ohm, 4000W @ 2 Ohm
Dimensions (W x H x D) 12.4" x 2.71" x 25.86"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
HK-802SX:
Remote Bass Control
THD @ 4 Ohm
THD @ 2 Ohm
THD @ 1 Ohm
S/N Ratio: >90dB
HK-4000D:
Remote Gain Control
2 Ohm Mono Stable
