FS: Kicker 2010 dx100.2 bnib **Pics**
Zeuslicious
<< 28hz feels good
5,226
SD CA
1. Product:
KICKER 2010 DX100.2 BNIB
2. Specs:
RMS Wattage at 2 Ohm x 2 Channels: 50
RMS Wattage at 4 Ohm Bridged x 1 Channel: 100
RMS Wattage at 4 Ohm x 2 Channels: 25
Stable down to: 2 Ohms
Active Crossover: 18 db/Octave High Pass Fixed @ 100Hz, 18 db/Octave Low Pass Fixed @ 80Hz
Bass Remote Included: No
Bass Remote Capable: No
Channels: 2 Channel
Cooling Type: Heatsink
Frequency Response: 20 Hz - 20 kHz
Input Sensitivity: Low Level: 125mV-5V, High Level 250mV-10V
Recommended Amp Kit: 8 Gauge
Signal-to-Noise Ratio: &gt;95 dB, a-weighted, re: rated power
Dimensions (in): Height 2-1/8" x Width 8-5/16" x Length 8-3/8"
CEA-2006 Compliant: Yes
3. Description/Condition:
BNIB
4. Price:
$59.99 Shipped No trades!
5. Pictures:
Friday Again! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
615
Zeuslicious
<< 28hz feels good
Zeuslicious
SD CA
Zeuslicious
    May 18, 2024
    May 18, 2024
