This is an incredible unit. MINT condition. Here are some specs:
Mount this great-looking Kenwood KGC-9044 EQ/crossover in a DIN-sized opening in your dash, and fine-tune your multi-amp system without leaving the driver's seat. Three pairs of preamp outputs (front, rear, and non-fading for your sub amp) give you maximum flexibility in designing your system. These gold-plated preamp output jacks pump out a 4-volt signal, for maximum dynamic range, signal-to-noise ratio, and signal integrity, with minimal distortion.
Selectable high- and low-pass electronic crossovers (each with selectable full-range pass-through) let you send each amp the precise frequencies your speakers require. You get an 11-band equalizer with 12 dB boost or cut on each band, and your choice of 8 high-pass and 3 low-pass settings on the crossovers. Choose from 6 factory-preset EQ curves, or program in 3 EQ settings of your own creation. A multicolor 11-band spectrum analyzer gives a cool visual display of the sonic contours you've selected.
Important Note: This unit has no built-in amplifier — must be used in conjunction with one or more external amplifiers.
Key Features:
detachable face
11-band equalizer, 12 dB boost or cut for each band
11-band multicolor spectrum analyzer display with white LED backlight
3 sets of gold-plated 4 volt preamp outputs: front, rear, and non-fading
3 user-programmable EQ curves
display contrast and dimmer adjustment
low-pass electronic crossover (50/80/120 Hz)
high-pass electronic crossover (40/60/80/120/150/180/220 Hz)
signal-to-noise ratio 88 dB
THD 0.01%
7-3/16"W x 2-1/8"H x 6-11/16"D
These average $200 on eBay plus shipping. I will let this go for $200 shipped to your door. VERY VERY nice unit. Pics available on request, and I will post some when I get the chance.
Key Features:
detachable face
THD 0.01%
