Mint condition Kenwood KAC-X1R with original box and packaging with all documents and the optional remote bass knob. This remote allows you to choose the center frequency and amount of boost youd like. Sorta like a basscube. Handy.
Ive used this on a 4 ohm Audiomobile MASS 12 setup for a while. Never overheated, never got too hot. Bought new, not refurbished. Solid amp.
Specs:
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 600 watts x 1 channel
RMS Power @ 2 ohms 1200 watts x 1 channel
RMS Power @ 1 ohm N/A
Bridged RMS Power Not Bridgeable
Peak Power Output 2400 watts x 1 channel
Amplifier Specifications
Amplifier Class D
Number of Channels 1 - Mono
ISF (Infrasonic filter) Switch
B.R.F. (Band Reject Filter) FREQUENCY control
Accepts 1/0 Gauge Wiring
Slave Amplifier Output
Digital Read-Out Display
Remote Input (Optional)
Fuse Rating: 25A x 3
Dimensions: 13-3/8" L x 8-7/8" W x 2-3/8" H
Total Peak Power Output 2400 watts
Total RMS Power Output 1200 watts
Maximum Input Gauge Size 1/0 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.5%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 40 - 200 Hz
Subsonic Filter 15 - 60 Hz
Signal-to-Noise Ratio 105 dB
Channel Separation N/A
Bass Boost 40 - 100 dB
Bass/Gain Remote -Optional (Accessory required and sold separately) - Incuded
Fan Cooled yes
Fuse Rating 25A x 3
CEA-2006 Compliant Yes
$190 shipped in original packaging with all documents.
You could still save a little if you dont want the box and documents.
Price is firm. Remember this bass remote was an additional $30.
Refs:
http://www.diymobileaudio.com/forum/itrader.php?u=823
Specs:
Amplifier Class D
Fan Cooled yes
Fuse Rating 25A x 3
Refs:
