Bought this about 6 months ago, works and looks great. I have the original box, but cant seem to find the manual. If you want pictures of the actual amp just let me know.
Got these specs from:
http://www.techronics.com/index.cfm?fuseaction=product.display&product_id=2062&aff=45847
1-Ohm Stable
Maximum Output Power: 1600 Watts x 1
Dynamic Power: 566 Watts
Output Regulation: Under 0.2dB (4 ohms)
R.M.S. Power Output (1-Ohm/1-Channel): 1016 Watts (1.0% THD+N)
R.M.S. Power Output (2-Ohms/1-Channel): 919 Watts (1.0% THD+N)
R.M.S. Power Output (4-Ohms/1-Channel): 533 Watts (1.0% THD+N)
Signal-to-Noise Ratio: 74dB (4 ohms)
AMS Amplifier Management System (-15 to 15 dB bass level control, Q factor control, bass/treble frequency control)
Variable 50-200 Hz low-pass filter at 24 dB per octave
Switchable subsonic filter (0/15 Hz, 24 dB/octave)
Requires 4-gauge power and ground leads wiring and hardware not included with amplifier
LED status display (AMS settings, voltage, current, temperature, fan speed, and protection status)
Cooling fan
Dimensions: 15-3/16"W x 2-7/16"H x 10-7/16"D
$175 SHIPPED
1-Ohm Stable
Cooling fan
$175 SHIPPED
