Sold FS: Kenwood 1600watt amp $100 shipped
cecilcohen
NJ
Asking $100 shipped or can pickup in NJ
The KAC-X810D Mono subwoofer amplifier can send up to 1000 scorching watts (at 1 ohm) of Class D technology power to your subwoofer with high efficiency and minimal heat. The 24 dB per octave crossover lets you trim down the frequency range of the signal being sent to the sub for extra tight bass, while the phase inverter (0-180 degrees) keeps your rear mounted sub(s) firing in sync with your front speakers, for total sonic harmony.
400 watts RMS x 1 at 4 ohms
800 watts RMS x 1 at 2 ohms
1,000 watts RMS x 1 at 1 ohm
Bass Management System
50-200 Hz low-pass crossover, 24 dB/octave
infrasonic filter (15 or 25 Hz selectable, 24 dB/octave)
12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB when connected to a Kenwood Excelon receiver equipped with BMS controls)
requires 4-gauge power and ground leads (see "Wiring Recommendations" under Detailed Info for more information) wiring and hardware not included with amplifier
preamp outputs
speaker short, low battery, thermal overload, and DC protection
variable color indicator
gold-plated terminals
detachable terminal covers
17-5/8"W (14-5/8" without terminal covers) x 2-5/16"H x 12-3/8"D
cecilcohen
cecilcohen
NJ
cecilcohen
