Sold fs: jl 10w0 8ohm
85Caprice4d
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Ohm Load: 8 ohm, (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 0.50-0.90 cu.ft. (14.0-25.5 liters)
Ported Enclosure Range: 0.90-1.50 cu.ft. (25.5-42.5 liters)
VRCª Technology: YES
Brand new I have seen 225. (sounds like a bit much yo me)(http://www.modyourcar.com.au/jl-audio-10inch-subwoofer-10w0-p1815)
EDIT!
Asking for $60 shipped obo
This speaker was used daily on 150w max over the summer. Sounded fine.
Cosmetically a 7/10
Functionality 10/10
The only thing I have noticed wrong on this sub is that the fabric ring around the cone (made of wood covered by a cheap fabric) has the fabric peeling. Other than that, there are a few TINY white specs on the cone, probably from paint or something? Easily cleaned
Compared to Memphis Pr 12"
(Memphis may also be for sale soon)
The only thing wrong with this sub is the small problems around the screw holes. Makes no difference in sound quality and no difference in anything other than cosmetics.
Also have a 10" wedge box that this was in, but i question the quality. The box is somewhat old and was used in a dump truck. If you want the box Ill do $5 + shipping on the bitsch.
60 shipped - lowest I'll go - thats like 35-40 for the sub and the rest for shipping //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
bump - no one?
for 60 you are basically paying $40 for this jl 10w0. Its not a bad woofer. I had it In an 85 caprice running off of 120 true watts and even through the steel trunk, you could feel it in the car.
I will throw In the box for 5$ + cost of shipping - but i think i already mentioned - the box for sure needs caulking on the inside to seal air leaks. Prefab box
I need to sell this A.S.A.P. Something has come up and I need to sell - pm me serious offers but I really would like to stick to 60 if possible.
85Caprice4d
85Caprice4d
Milwauke, WI
85Caprice4d
