Item(s) for Sale: Image Dynamics Q. 700.2 2 channel amp.
Item has some scuffs on top, see pics below. The amp works fine just some cosmetic issues. I can send more pics to whoever just pm me your cell and Ill text them, its easier for me that way.
Q Series 2-Channel Class A/B Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 175 watts x 2 chan.
2 ohms: 325 watts x 2 chan.
Bridged, 4 ohms: 650 watts x 1 chan.
Optically isolated MOSFET power supply
LED power indicator
Variable bass boost(0 to +12 dB bass boost at 45 Hz)
Soft Start Turn-on
2/1 or Mono channel operation
Remote bass level included
RCA preamp outputs
Bi-Polar High-current output devices
Auxiliary full range output
Two-layer PC Board with heavy 2 oz copper
Massive ground planes and precision caps
Frequency multiplier
5-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Input sensitivity:
Low level: 150mV-6V
Variable high-pass filter (50-5000 Hz, 12 dB/octave)
Variable low-pass filter (50-5000 Hz, 12 dB/octave)
Variable subsonic filter (10-100 Hz, 12 dB/octave)
Damping factor: >100
Frequency response: 10-30,000 Hz
Signal-to-Noise ratio: 98dB
Dimensions: 17-3/4"L x 8-1/2"W x 2-1/4"H
I'm really not sure what its worth with the damage so I'm starting at $300, I am also open to trades, looking for good sq 4 channel that will do 80@ 4ohmx4.
we can work it out
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). View attachment 26539953View attachment 26539952
LED power indicator
Soft Start Turn-on
RCA preamp outputs
Input sensitivity:
Low level: 150mV-6V
we can work it out
