Sold FS: Image Dynamics iDMAX 12" D4 V3 and Zapco Reference 500.1 MINT!
quix
I have a flawless setup here.
First is the Image Dynamics iDMAX 12" D4 V.3. It has dual voice coils. Anyone on here should know about Image Dynamics. I have kept all my equipment clean and never bashed anything around. Comes in a large 1.6 cu ft sealed box for loud, clean sound. It has a really light scuff on the face but does not affect sound quality in anyway.
Also, I have a very mildly used Zapco Reference 500.1 amp. Cosmetically it's not too bad (8 out of 10) and performance is spot on (10/10). Symbilink is included for absolute clean sound (creates balanced signal).
I'll also include a Navone Engineering low pass filter with the amp (input speaker leads, output RCA). The pass is at 150hz. This really gives truly clean and clear bass in addition to Zapco's clarity!
I also have all wiring that was used for $10 if you purchase the amp (includes inline 60 amp fuse AND extra new 60 amp fuse). 4 gauge power and ground wires. All in perfect shape. Will not sell this separately unless amp sells first.
Will separate each for $250 OBO, plus shipping
Shipping will be calculated if you provide a zip code. However local pickup would be preferred.
$480 OBO takes the perfectly matching setup, plus shipping
Zapco 500.1 Amp Specs:
Total Power (14.4V @ 1kHz)
.2% T.H.D. 500 watts
Rated Power T.H.D.+N
350 watts x 1 @ 4W; .04% (700 watts MAX)
500 watts x 1@ 2W; .20% (1000 watts MAX)
Frequency Response 20 – 20kHz, +0/-.5dB
S/N Ratio: 80dB
Transient Distortion (4W, 35W): .013%
Slew Rate: 25 V/mS
Damping Factor: 250 @ 4W
Input Sensitivity
Balanced (DIN) 250mV – 10V
Max. Current Requirements 40 Amps @ 500 watts
Idle Current .65 Amps
Dimensions 12”L x 7.5”W x 1.95”H
Image Dynamics IDMAX 12" V3 D4 Specs:
Power RMS: 1000 Watts EIA, (1800 Watts Music Program)
Recommended enclosure: 1.30 -1.52 cu.ft. sealed (1.8 - 2.50 cu.ft. vented
@ 28Hz), Infinite baffle
Xmax (linear): 24.9 mm, (0.98 inch) one-way
Xsus (maximum): 3.5 peak to peak
Impedance: dual 4 ohms
Sensitivity: 1W/1M
93.1 dB 50-150 Hz ground plane. No 88.4 dB
Mounting depth: 8.25"
Mounting diameter: 11.0"
quix
quix
Corona, CA
quix
