i got it off
ebay the amp ran 3 15''s in a sealed box and i had the gain too high i told them sound shop ppl lower the gain guess they didnt listen i blew them because i continuosly played the music loud for bout 1hour straight..i was cruising btw amp is in good condition im not sure if its modded it also comes with the amps gain switch bass control remote.
4,000 WATT RMS DIGITAL MONO AMP
CLASS "X" (MORE EFFICIENT THAN CLASS "D" MONO
2000 RMS @ 4 Ohm
4000 RMS @ 2 Ohm
2 OHM STABLE
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated RCA Jacks
Double Sided Epoxy PCB Board
Platinum Plated Block Terminals
Stainless Steel Finish Heat sink
Quiet, But Powerful Fan Cooled System Built-In
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter @ 50Hz - 350Hz
24dB Subsonic Filter @ 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control @ 45Hz
Input Sensitivity: 0.2 - 8V
Dimensions: 12.4” Wx 2.71” Hx 25.86” D
