Sold fs: Harrison Labs Flux Cap 100a
ssackett
Evo Audio
1. Product: Harrison Labs Flux Cap
http://www.hlabs.com/products/fluxpower/
2. Specs: 100a 16v DC-DC convertor
3. Description/Condition: Like new!! Place this unit right before your 16v battery bank in your trunk in your ride and what it does is take your car 14.xx charge and converts it into its set point charge which is about 18.2!!! Simple easy solution to have a 16v system and not change a dang thing under your hood!!!!
4. Price: : $250 shipped!!!!!!
5. Pictures:
Very badass!!! To explain how simple this is guys.. If i were to drive to a buddys house today with my flux cap and a couple 16v batts.. We could place the 16v batts in his cargo area.. Hook up his pos run to the Flux Cap then hook the flux cap to the 16v batt bank and presto!!!!! 16v system in under 20mins!!!!!!!!!!!!
what does the specs mean when it says 100 amps ?
does that mean your alt can not be more than 100 amps?
or
your system can not draw more than 100 amps?
thanks
or
thanks
It means the flux cap will output 100 amps maximum to the battery bank it is charging. Your system can be more than 100 amps but you will periodically have to let off to let the bank charge.
Quick tread jack. (only cuz I might be interested)
Jacob, are your amps draw less power running at 16v over 12 / 14v running at the same wattage?
Yah, they will draw less at an equal power output.
They have the potential to draw more, though, as power output potential is higher.
You want my PP addy now or later Rollerdj?? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
If you still have it after I get my tax check back then yes. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Jacob, thanks. I knew that was the case with AC stuff, but didn't know if it was the same when it car to car amps.
ssackett
Evo Audio
ssackett
CA
TnT_Sounds
