Sold FS/FT: PDX 1.600, DIYMA12 x 4.
egoaudio
PDX has been sold!
I have 4 DIYMA 12's that I recently purchased. All have been opened but only 2 have been auditioned. I have treated them all with much TLC. they are very nice sounding woofers I just realize that I am more of a bass head than a pure SQ guy so I may get rid of all of them depending on demand.
Looking for $100 + shipping each firm.
pics:
Best regards,
Erik
They are single 4 ohm.
Features:
* Heavy 12 spoke cast aluminum basket.
* Massive 3”x 2” 4 layer copper voice coil wound on a black aluminum former for high thermal powerhandling.
* Custom machined aluminum ring and thick pole sleeve for ultra low driver inductance and inductance related distortion.
* Dual spider design improves mechanical powerhandling and stability.
* Sewn-in tinsel leads prevents dreaded “tinsel lead slap” noise.
* Ventilation beneath the spider and through the large pole vent maximizes voice coil cooling.
* Durable, long lasting rubber surround.
* Removable one piece rubber gasket provides an air tight seal for mounting.
* White anodized aluminum cone.
* Spring loaded terminals for easy connection.
* Attractive multi-magnet motor
* Extremely low distortion and BL compression
Specs:
* Acceptable enclosure size: .25 to 1.5cft sealed box (larger enclosures INCREASE powerhandling)
* Acceptable amplifer power range: 200 to 1000 watts per sub
* Recommended for typical SQ use: 1cft + 300 watt amplifier power
* Single 4 ohm voice coil
* QTS: .354
* FS: 25hz
* VAS: 41.7 L
* RE: 3.6 Ohm
* BL: 22
* SPL: 84.3 dbwm
* Le: 1.3mh
* Xmax: 23mm 1 way (71% bl, 25% cms)
* Xmech: 64mm peak to peak
* Weight: 37 lbs
* Cutout diameter: 28cm
* Mounting depth: 16cm
* Driver volume: .15 cft
no, not by any means. I tested them in sealed and in a passive radiator enclosure and they perform well in both. I prefer the extra output of the PR enclosure, still has plenty of SQ. I tuned at 25hz, 30hz, 32hz and 35hz and all sounded nice. they all sound nice. personally for music (in car) they are best at around 30 - 35. Very accurate woofers though.
EGO
egoaudio
egoaudio
Seattle
Gville
