FS/FT: ICS M16A3 Airsoft Gun/Charger/Mag/Batteries
dustinr
Hello everyone.
Up for sale is my Airsoft rifle. It is a ICS M16A3.
Specs are:
Automatic Airsoft AEG (Airsoft Electric Gun) Rifle
-Unique Serial Number Assigned
-Metal Receiver
-Metal Outer Barrel
-Metal Split Gearbox
-Steel Gears
-Silicon Steel bushings
-Turbo 3000 Motor
-Made by ICS.
- 360 fps (0.2 g BB)
- Motor: Turbo3000
- Hi-Cap Mag: 400 Rounds
- Full Metal
- Made in Taiwan
- Rate of Fire: 920 rounds per minute
- Fire Modes: Semi-auto, Full-auto, Safe
- Hop-up: Adjustable
- Upgrade: We charge $45 to upgrade it to M120 Spring (400-420 FPS)
Cosmetically 9/10
Mechanically 9/10 (Safety sometimes doesn't work, I'm sure it would be a easy fix)
Charger specs:
- Quick Charges all batteries
- Adjustable Amps w/ Display
- Discharge Batteries Completely prior to Charging
Charge Times:
Battery (Volts) (mah) Current (A) Charge Time (mins)
9.6 V 600 mah 1 Amp 30 Minutes
9.6 V 1100 mah 1.5 Amps 30 Minutes
9.6 V 2200 mah 3 Amps 30 Minutes
8.4 V 1800 mah 3 Amps 30 Minutes
8.4 V 2400 mah 3.5 Amps 30 Minutes
8.4 V 3000 mah 2.5 Amps 45 Minutes
This specific gun has no mods. Included will be 2 batteries, 1 of which I will have to track down. Also included, is my Prolux ALFA-3 battery charger. See pics for additional details on that.
I bought the gun spring/summer of 2007 and has seen slight play since then. If I had to estimate it's play time I'd say roughly about 4-5 hours. Batteries have seen a recharge once or twice in their lifetime.
I'm selling this, because I have no use for it. It has hidden itself underneath our bed for quite some time now and while I still have some interest in the hobby, it is not on the top of my priority list at the moment.
From doing a quick, general search of the retail price of one of these.. I concluded it to be around $275-$380.00. My price with everything you needed is included is going to be $195.00+Shipping, OBO for the M16A3, charger & batteries. Buyer may come pick this up if you are local.
If you have any questions or need any further pictures, please do not hesitate to ask.
I will also be on the look out for the original box, as well as the paperwork it came with.
Here are the pictures and thank you for looking.
Dustin
*Note Case is not included. If you are interested in it, I will work on a price. Thank you.
dustinr
dustinr
Moberly, Missouri
undeadxsunshine
