Amp is in great condition with only a minor scratch or two and everything functions perfectly. It has not pushed out more than about 600 RMS to anything due to the subs I've been running. Looking for around $100 + shipping or would like to trade (and could throw in cash) for an amp that does 800-1,000 RMS @ 2 ohms. I'm currently at school but I would like to at least set up a buyer/trade so when I go home in 2 weeks, I can ship it then. Thanks!
# Class A/B MOSFET Power Amplifier
# 2 Ohm Stereo Stable
# MOSFET High Speed Switching Power Supply
# Non-Regulated Power Supply
# Double Sided Epoxy Circuit Board
# Air Induction Fan Cooled
# RCA (Low Level) Inputs
# Speaker (Hight Level) Inputs
# RCA Outputs
# Variable High Pass Crossover : 50Hz - 750Hz
# Variable Low Pass Crossover : 50Hz - 120Hz
# Variable Subsonic Filter : 20Hz - 50Hz
# 12dB Crossover Slope
# Signal to Noise Ratio >100dB
# 0.02% T.H.D.
# 18dB Bass Boost
# Bass Boost Control On/Off
# Phase Shift 0° - 180°
# 1/2/3 Channel Operation (Mixed Mono)
# Tri-way capable
# Soft Start Circuitry
# High Gloss Chrome Plate Finish
# Blue Illumination
# 4-Way Protection Circuitry: Thermal, Short Circuit, Overload, DC Offset
# 30A x 2 Fuses
# Dimensions: 11-1/16"W x 1-7/8"H x 11-7/8"D
# 2 x 200W RMS @ 4 Ohm
# 2 x 400W RMS @ 2 Ohm
# 1 x 800W RMS @ 4 Ohm
# 1600W Max Power
# RCA Outputs
# 0.02% T.H.D.
# 18dB Bass Boost
# Tri-way capable
# Blue Illumination
# 30A x 2 Fuses
# 1600W Max Power
