Sold FS/FT Alphasonik PMA640HCA 1920 watts @ 1 ohm
blfuller123
I have an Alphasonik PMA640HCA 4-Channel High Current Amplifier. It has 7 hours on the hour meter and was only used to run 2 10s. I have the original box, and is 9.5/10 cosmetic because it has been installed and 10/10 functional condition.
$325+shipping from 30517 or trade for a larger amp. Looking for a larger amp 3K at 2 ohms, I have 2 d2 subs to run. I will put cash towards the right amp.
Amp Specs:
4-Channel High Current Power Amplifier
RMS Power Rating:
160 watts x 4 chan. @ 4 ohms
290 watts x 4 chan. @ 2 ohms
490 watts x 4 chan. @ 1 ohm
500 watts x 2 chan. @ 4 ohms bridged
825 watts x 2 chan. @ 2 ohms bridged
960 watts x 2 chan. @ 1 ohm bridged
Hour Meter
Remote Mount Digital Voltmeter Included
Bass Remote Included
Heavy Duty Heat Sink
Beveled Clear Acrylic Protective Cover
1 Pair RCA Outputs
Tiffany-Style Input and Output RCA Jacks
High Speed Switching Power Supply
Double-Sided Glass Epoxy Circuit Board
Variable Low-Pass Filter: 50 - 250 Hz
Variable High-Pass Filter: 50 - 250 Hz
Variable Subsonic Filter: 15 - 60 Hz
Variable Bass Boost @ 45 Hz: 0 - 18 dB
Input Sensitivity: 200 mV - 8 V
Input Impedance: 10,000 ohms
4-Way Protection Circuitry: Thermal, Short-Circuit, Overload, and DC Offset
On-Board Hook Up Terminals
Frequency Response: 5 Hz - 50 kHz
Dimensions: 19-3/4" L x 9" W x 2-5/8" H
How much locally? I'm just south of Atlanta.
My oh my that does look sharp.
And I believe these are .5 ohm stable per channel...dont quote me on that, I'd have to call around first haha
Edit - Then again it's rated for 1ohm bridged, so meh, should hold onto a .5
I have never run it at .5 ohm, but have run it 1 ohm bridged with no problems.
blfuller123
blfuller123
DFW
blfuller123
slater
    Oct 4, 2025
    Oct 4, 2025
