Sold FS/FT.... 18" Super Konaki Custom PSI sub
andrewtexas123
1. Product:
2. Specs:
Its an all black, CF Capped, MONSTER 18" subwoofer. It will do very well in ported applications from 4ft up to 8ft with a mild tuning (somewhere between 28 and 35) for daily ground pounding.
It has a very healthy 3.2" p-p of excursion, a fairly low Fs, and will drop low when asked to!
Will withstand roughly 2000-3,000w rms depending on the user and the application.
Brand New Konaki Motor Assembly w/ Blank Magnet Boot
8 Layer D2 ohm Aluminum Flatwound Voice Coil
Dual 9" Linear Spiders
Dual Sewn Leadwire
18" Heavy Duty Cone Assembly
7" Carbon Fiber Dome Dustcap
8ga Direct Connect Wiring
Wrap Around Rubber Gasket
NOW HERE'S THE COOL PART:
The black 18" 6 spoke basket has 1.5" holes milled into it to allow for direct access to the bolts holding the basket to the motor. These bolts can be easily removed with a 10mm wrench (ratchet wrench is MUCH easier), allowing the entire top assembly to be removed and swapped to another motor, or to allow for a different top assembly to be mounted to the motor.
The removal of the basket isn't something that I would call "quick", but it's definitely do-able. I've taken it off and on quite a few times now.
I've tallied up the total cost for this subwoofer, pricing each individual option, and the value of the subwoofer would come out to be right at $500.
The Konaki motor is arguably as good or better than most large sub motors out there now. It has a large enough gap to allow for an 8 layer coil, large 220mm magnets, and tons of cooling vents in the motor. Its just as strong as most, and cools better! It's a VERY proper choice for a high output daily subwoofer like this. I could have used a Nightshade or RE MT motor for this woofer, but the Konaki is a better choice IMO. It took it off a built, but brand new 1207A.
If someone is interested in just the top assembly, I would consider selling it without the motor! The top would work with lots of different motors! It would be just great on RE MT's, Sundown Nightshade, Fi BTL's, etc etc etc... basically anything with a large enough gap, a standard bolt pattern and a top plate within 2mm of 25mm in height!
These are ALL BRAND NEW parts. This is a BRAND NEW subwoofer. It's got tons of add-on's and upgrades above most anything available right now. If you need a badass 18" that will drop LOW, this is it!
T/S Parameters are as follows:
Sd: 1230.00 cm^2
Vas: 126.00 l
Mms: 443.08 g
Rms: 12.52 Ns/m
Fs: 31.0 Hz
Bl: 26.76 N/A
Re: 3.90 ohm
Qms: 6.89
Qes: 0.47
Qts: 0.44
Spl: 90.9db 1w/1m
3. Description/Condition:
Used about 3 weeks and not given more then 1500 watts
4. Price:
$375 shipped
Trade for a kick *** 12"
5. Pictures:
Bro, Dude's legit in my book, He even shipped first. I am 100% satisfied with his service & my product.
Thanks man michallane is just a little immature.. You are right though I ship very quickly and even spent an extra $20 out of my pocket for priority shipping..
might be mine so back off, compared to a btl 18?
really quite tough to compare a custom built sub to a btl. This can be very rare, but also can be re-created, but is an amazing sub! removable top assembly is a nice tough. you can have dave over at psi make a 15" or 12" top assembly... Comparing this to a btl would also depend on its t/s parameters and what the users goals are for the sub. period it would be very tough but its a great sub looks like it would be fun. pull the trigger //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and micheall you do need to cool down from his statement over on caco. i understand you where frustrated aswell i was, but this is his FS thread so dont do that man, not cool. no matter what forum you are on. Directed towards Andrew, its never ok to take 20 days to ship an item, being left out of the loop sucks, but that is neither here nor there. GL with you sale!
andrewtexas123
andrewtexas123
Danville, Ca
DonH
