Sold FS/FT: 15" PPI Flat Piston Pro RARE **PICS**
JiggaD369
Bedroom Gangster
NJ
Selling one of the best SQ subs ever produced according to others. These “old school” subs feature carbon fiber/Nomex honeycomb flat piston diaphragms driven by massive magnets on a die-cast aluminum frame. These subs were built like Sherman tanks, assembled in Phoenix with top quality parts from US speaker component factories. The PRO Flat Piston Subwoofer went on to win two SPL world championships in the well-known TeamGates “Beast” Bronco. This 15" model features an absolutely massive motor structure with a 5” diameter voice coil for handling serious amounts of power. This monster weighs in at 42.5 lbs! It is in MINT condition. Asking 250 plus shipping. Serious buyers only! I also have two 10" Flat pistons if anyone is interested.
FEATURES:
Rugged die-cast basket
Ultra-rigid carbon fiber/Nomex honeycomb diaphragm
5” edge-wound voice coil on Kapton former
Aluminum trim ring
Rubber surround and large dual spiders
Gold-plated heavy duty terminal posts
Forged steel back plate with Precision Power logo
Vented pole piece & magnet cavity for superior cooling
Designed for use in bandpass, vented or sealed boxes
Completely Designed And Handcrafted In The USA
Specifications:
Power handling: 600 WRMS
Resonant frequency: 31Hz
Qts: 0.34
Qms: 1.21
Qes: 0.47
Vas: 108.43 liter
Nominal impedance: 4 ohm
Sensitivity (SPL @ 1W/1M): 90.51dB
Linear excursion: +/- 6.25mm
Peak to peak excursion: 31.5mm
Mms: 207.04 grams
Sd: 0.0790 sq. M
Bl: 18.73 TM
Net weight: 41 lbs.
DIMENSIONS:
15.143" (DIA) x 5.63" (H)
Mounting hole diameter: 13.75”
Mounting depth: 5.00”
Speaker displacement: 0.21 cu. Ft.
PICS:
http://img.villagephotos.com/p/2004-11/893546/1212061432.jpg
http://img.villagephotos.com/p/2004-11/893546/1212061432a.jpg
http://img.villagephotos.com/p/2004-11/893546/1212061434.jpg
http://img.villagephotos.com/p/2004-11/893546/1212061434a.jpg
I'm trying to look for the T/S info on the 10's online but can't seem to lay my hands on it. They are also in mint condition. They're in a box if you want it like that but only pickup with box. Otherwise I'm willign to ship them. They're SVC 8 ohms.
I'm having a hard time locating the T/S parameters on them. Help would be appreciated. The tens belong to a friend of mien so pics will be available on thursday if that's not a problem.
To me it was more than enough. BUt it depends on your preference. Ask around in the subwoofer section. I had it ported BTW.
JiggaD369
Bedroom Gangster
JiggaD369
NJ
JiggaD369
