FS: Fosgate Punch HX2 12" D4 BNIB!
OldSchoolRF
1. Product:
Rockford Fosgate 12" Punch HX2 D4
Brand New In Box!
2. Specs:
Description :
One low-frequency roar from the RFD2212 and those inferior subwoofers will be scrambling for cover. This Punch HX2 12" subwoofer is built with the famous Rockford Fosgate attitude — a no-compromises commitment to deep, powerful, and realistic bass.
The FIBERlock cone of treated cured paper is strong and light for high performance and excellent transient response. Those bass notes go down smooth, too, thanks to a durable Santoprene rubber surround that controls the cone's path for maximum excursion.
The cast aluminum frame basket reduces flex and resonance for greater accuracy, while aluminum formers allow the voice coils to dissipate heat quickly. The dual 4-ohm voice coils can be wired as a 2-, 4-, or 8-ohm load, giving you more options when hooking up your system.
Note: If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Details:
CONsealer gasket hides mounting screws and prevents air leaks around the frame
frequency response 26-200 Hz
power range 150-500 watts RMS (250 watts per voice coil)
peak power 1,000 watts
sensitivity 88 dB SPL
top mount depth 5-13/16"
sealed box volume 0.8-4.0 cubic feet
ported box volume 1.75-4.0 cubic feet
Recommended Q-Logic Box Type: 1, 2, 3
3. Description/Condition:
This classic is brand new in the box. It was purchased years ago but I never ended up using it. It is 100% mint and comes in its original box with manual and Team RF window sticker. It has never been mounted, wired or powered. One of my favorite subs of all time. Will handle well over its 500 rms rating. Gasket is not included as I did use that for another project. I have a generic one I can include if you want it.
4. Price: :
$220 shipped with insurance & tracking OBO
5. Pictures:
OldSchoolRF
OldSchoolRF
Kentuckiana
OldSchoolRF
