Sold FS: ESX Quantum Q75.2 Amplifier... Zed Audio Goodness
omarmipi
I have an ESX Quantum Q75.2 amplifier for sale. It is the perfect amplifier to go active 2-way (provided you have a sub low pass) because its ability to high/low pass 50 Hz - 4,200 Hz. Add another amplifer to the line out and BAM your ACTIVE!
Its power ratings are at 12 volts so you can expect more power then the listed numbers. It has tons of power configurations and has balanced inputs (noise elimination). And of course it is made by the Zed Audio man, Steve Mantz.
It is in perfect working condition and good physical condition with a couple flaws. The ESX logo is missing and the silk screen is faded on the power/ground/wires side. I will include a copy of the manual so you will be able to make out the terminals.
Power
2 x 75 W @ 4 ohms (12V)
2 x 120 W @ 2 ohms (12V)
1 x 240 W @ 4 ohms bridge (12V)
1 x 85 W @ 4 ohms bridge "TRUE MONO" (12V)
1 x 160 W @ 2 ohms bridge "TRUE MONO" (12V)
1 x 230 W @ 1 ohms bridge "TRUE MONO" (12V)
1 x 120 W @ 4 ohms bridge "TRUE MONO/HI V" (12V)
1 x 210 W @ 2 ohms bridge "TRUE MONO/HI V" (12V)
Two amps can be bridged to double the power
Imp Sensitivity
Balanced: 300mV - 18V
Unbalanced: 150mV - 9V
High/Low Pass Crossover
50 Hz - 4.2 KHz @ 12 dB/octave
Dimensions
73 mm x 232 mm x 180 mm (2.87" x 9.13" x 7.08")
$140 shipped fees included
__________________________________________________________
omarmipi
omarmipi
Houston, Texas
omarmipi
