Sold FS: Eclipse EA3422 4x50w, 2x140w bridged
headless
Up for sale - 1 Eclipse EA3422 4/3/2 channel amplifier. This amp would be perfect to run a set of moderate power components such as rainbow slc's, etc. It is capable of:
Specifications
13.8V Power Supply
Max Power Output 123W x 4 ch (2 ohms)
Power Output (RMS Continuous Power) 2 ohms 70W x 4 ch
4 ohms 50W x 4 ch
4 ohms bridged 140W x 2 ch
THD (Rated Power) @ 2 ohm stereo 0.008%
@ 4 ohm stereo 0.004%
@ 4 ohm bridged 0.008%
Signal to Noise (A-weighted 4 ohm) 105dB
Freq. Response @ 4ohm stereo 20Hz-20kHz +0,-0.7
Crosstalk 4ohm -70dB
Slew Rate 10V/us
Damping Factor @ 60Hz > 200
Input Sensitivity (preout) 0.2-5V
Input Sensitivity (Amp-out) 0.4-10V
Max Current Consumption (4ohm) 50A
Channelflex Crossover
High-Pass Freq Range - 12dB/octive 50~200Hz
Low-Pass Freq Range - 12dB/octive 90Hz (fixed)
Bass Boost (@45Hz) 0~9dB
Subsonic Freq. Range - 12dB/octive 20Hz
Dimensions (W x H x D) 10.82" x 1.97" x 10.82"
My camera took a shit on me, so here's a picture of it before i took it out of my car - cosmetically, she's a bit beaten up with some scratches on the exterior. In great working order though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Both high level inputs (in case you want to amplify some speakers but keep your stock deck...) and rca line level inputs. This amp can be configured to 4x50w, or 2x50 and 1x140w for a pair of efficient fronts and a low power subwoofer setup from one amp - or, the way i used it, bridged to 2x140w to power a set of components up front //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Asking 100$ shipped.
I've sold a set of rainbow germaniums to zxcvtypo and an epicenter here also though i don't remember that poster's name...
headless
headless
Florida (Tallahassee)
sLyx620
