FS Eclipse 3241 4x50w 4 channel amp
kmarei
Eclipse 3241 4 channel amplifier
condition: Very good
Specs:
4x50w @ 4 ohm 12v
4x100w @ 2 ohm 12v
2x200w @ 4 ohm 12v
all specs losted at 12v so you will get more power at 14.4v
i'd guess 4x75w?
2x30A fuses
very good crossovers
you can choose from 50-200hz or 1500-6000hz high pass
and 50-200hz or 1500-6000hz low pass
also has preouts, with crossover, so your sub amp doesn't need a crossover
can also have non fading subs from the RCA preout
great for 3 way active setup, all you would need is an extra amp for the midbass, but it doesn't need to have crossovers, since you can filter the signal going out of the preamp on this amp
$110 shipped obo
overnight shipping included
kmarei
kmarei
Reston, VA
cf2004
