Sold FS: DLS Ultimate A3 and Ipod Video 30 GB
Snow90
DLS IS SOLD!
Next I have an Ipod Video 30 GB up for sale. I would give it an 8/10 for cosmetics just because of a few scratches on the surface. Ipod has been in a case since day one and will also include the case. Physical I will give it a 10/10, everything works on it just fine. Only thing I can think of that's wrong with it is once and a while, while holding down the play/pause buttom to shut the ipod off, it will not register until the 3rd or 4th time. If you are going to be using this to hook up to your stereo you should be fine and have no problems with it. Will come with original box and USB cord to connect to your PC.
Price Change: $70 Shipped within the U.S.
Also, forgot to post specs on the DLS.
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 150 W
Output power in 2 ohm 2 x 270 W
Output power in 1 ohm 2 x 425 W
Mono bridge mode 4 ohm 550 W
Mono bridge mode 2 ohm 870 W
Mono bridge mode 1.33 ohm 1000 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
Frequency range 10 Hz - 50 kHz
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
Low level output No
External cooling fan terminal Yes
High level input with auto start No
Dual DC inputs Yes
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Snow90
Snow90
West Allis
Snow90
