I'm downsizing to a passive setup so some stuff has to go.
DLS A4
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 4
Output power in 4 ohm : 4 x 85 W
Output power in 2 ohm : 4 x 145 W
Output power in 1 ohm : 4 x 220 W
Output power in 4 ohm bridge mode : 2 x 250 W
Output power in 2 ohm bridge mode : 2 x 400 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter front channels : Lowpass: 50-125 Hz. Highpass: 20-200 Hz / 60-600 Hz
Filter rear channels : Lowpass: 45-200 Hz / 90-400 Hz. Highpass: 20-200 Hz
Terminal for external cooling fan : Yes
Dual DC-inputs : Yes
Current draw, idle : 1,5 A
Current draw, maximum : 95 A
Dimensions W x D x H : 465 x 240 x 73 mm (18,30 x 9,45 x 2,87 inch)
Weight : 6,6 kg ( 14,55 lb)
The front is pretty close to mint. The areas around the mounting holes in the rear do have some scuffing/scratches. There's a pen-tip sized ding on the top in the 5th picture and to the right of the push-pin in the 6th.
$380 shipped, verified paypal.
DLS A4
Mode : AB
