Sold FS Directed A802 2ch 800W amp
guyrichy
For sale. 240$
lightly used Directed A802 800W 2 channel Amplifier w xover
I got this about 2 weeks ago and I have the receipt to prove it. It just has too much power for my taste! Barely touched. Works perfectly.
This is a great deal. It retails for 380. On ebay its 200 and after shipping and tax to CA its like 260. You can pick this up right away and put it into your system for a price less than ebay! If you are serious and you have an offer, email or pm me!
thanks for lookin
Product Name: Directed Amp 800 Watts 2 CH W/ESP A802
Model: A802
Category: Amplifiers
Manufacturer: Directed Audio
MAP Price: $379.99
Sale Price: $339.00
(Instant Rebate: - $40.99)
Free Shipping, FedEx Ground
Order Options:
Qty:
Description: High speed MOSFET switching power supply
Complimentary bipolar outputs
Thermal, DC offset, reverse polarity and short circuit protection
Built-in blue LED top panel illumination
External LED/Fan power jack
Built-in high performance, 12 dB/octave 2-way active crossovers
Switchable 8 dB bass EQ function
ESP® features:
Anti-theft protection and valet mode - renders your amp useless to thieves or parking attendants
Digitally programmed input voltage for fast, accurate system set-up
Input sensitivity lock-out mode - lock the tweakers out!
Built-in self-diagnostics - installer can recall shutdown history, avoids time-consuming service visits
Digital control over cooling fan operation, turn-on delay
Specs
Max Power 800
CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 150 x 2
CEA S/N Ratio (referenced at 1 watt/4 ohm) 75dB
CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 200W x 2 @ 2 ohm
Freq. Range 20-20Hz
Damping Factor >200
Input Sens. 150mV to 7.5V
Crossover var. 12dB 2-way
Bass EQ Yes 8db
RCA Output Yes Stereo
Protection T,S,D,R,O,L
Dimensions - inches W:10-3/4 H:2-1/2 L:13
T = Thermal, S = Short Circuit, D = DC offset, R = Reverse polarity, O = Over voltage, L = Under voltage
guyrichy
guyrichy
Los Angeles, CA
dleccord
