Sold FS: Diamond D3 400.2
bass_lover1
Metal Head \m/ \m/
I have here a Diamond Audio D3 400.2 in good cosmetic condition, I'll give it a 9/10 just because it has been used. Mechanically it works great. I'm selling because I picked up a JL 300/4 to use in my upcoming 3-way front stage.
I used this to power my LPG 26NAs and my BG Neo3s, it makes a great tweeter amp, and is powerful enough to use on a passive component set.
specs can be found on Diamond's website.
I'm looking to get what I paid for it which is 120+ shipping, I'll entertain trades as well.
# Pulse Width Modulated (PWM) MOSFET Switching Power Supply
# Extruded Aluminum Heatsink
# Double sided PC boards
# Nickel Plated RCA Low Level Audio Inputs
# Nickel plated, low resistance power and speaker connector blocks
# Power ON and Protection LED Lighting for Easy Diagnostics
# Thermal, Short Circuit, and Overload (Low Impedance) Protection
# 12 dB bass boost
# Chassis mounted ATC/ATO type automotive fuses
# Class AB Amplifier Topology
# Bridgeable Output Capability (4 Ohms)
# Stereo/Mono Mix Capability (Hybrid 3rd channel from 2 channels)
# Stable into 2 Ohm Stereo Loads
# Internal 12dB/Octave High Pass or Low Pass Filter (40-400Hz)
# Pass -Thru Line Output for Daisy Chaining Amplifiers
# Versatile for either full range or subwoofers
# Proudly Designed and Engineered in the USA
# RMS Output Power: 100 x 2 @ 4 Ohm Stereo
# 200 x 2 @ 2 Ohm Stereo
# 400 x 1 Bridged @ 4 Ohms
# Freq Response: 20Hz-20KHz
# Signal-to-Noise Ratio: >100dB
# THD: 0.05%
# Length: 12"
# Width: 8.5"
# Height: 2.25"
bass_lover1
Metal Head \m/ \m/
bass_lover1
NPR, FL
hrtbrk1
