FS: Couple of Tennis Rackets
dafobbishon3
I have a Wilson K Blade Tour 4(1/2) grip
Midsize Specs
Head Size:
93 sq. in. / 600 sq. cm.
Length: 27 inches / 69 cm
Strung Weight: 11.8oz / 335g
Balance: 8pts Head Light
Swingweight: 323
Stiffness: 65
Beam Width: 20 mm Straight Beam
Composition: 100% [K]arophite Black w / X Loop Weave At 3 & 9 o'clock
Power Level: Low
Swing Speed: Fast
Grip Type: Wilson Leather
String Pattern:
18 Mains / 20 Crosses
Mains skip: 8T,10T,8H,10H
One Piece
No shared holes
String Tension: 50-60 pounds
I have a Babolat Pure Drive Roddick Cortex Standard 4(1/2) grip
Midplus Specs
Head Size:
100 sq. in. / 645 sq. cm.
Strung Weight: 11.2oz / 318g
Balance: 5pts Head Light
Swingweight: 325
Stiffness: 70
Beam Width: 22-25 mm
Composition: Graphite / Kevlar
Power Level: Low-Medium
Swing Speed: Moderate-Fast
Grip Type: Syntec Grip
String Pattern:
16 Mains / 19 Crosses
Mains skip: 8T,8H
Two Piece
No shared holes
String Tension: 50-66 pounds
I want to sell these because I need money to buy a brand new racket.
The KBT is a (7/10) and plays very well. It is strung with a hybrid of Tecnifibre Polyspin on the mains and the Tecnifibre synthetic gut on the crosses and is strung at 53. There are some scratches on the paint as well as the gromment. The one thing with this racket is that at the bottom gromment, there's a couple of hair-lines. This isn't major because the hair-line doesn't penetrate the actual frame. It's only on the finish. So it's still very playable. This has a Yonex Super Grab over grip on it.
The Babolat PDRC Standard is a (5/10) and is unstrung. I've had this for a couple years. The thing with this racket is that there are numerous amount of scratches, and it is in dire need for a new top grommet. Other than that. it's fine. Once it's restrung it's great for play. This has a Head overgrip on it.
I would love to see the kbt gone at 80 + shipping and the pdrc at 50+ plus shipping or 110 + shipping for BOTH.
PM me or email me at da_fobbish_on3@yahoo.com
PICS:
AND IF YOU WANT MORE PICS, JUST ASK.
well how long have you been playing? and do you know your ntrp rating?
cause if it's low, you might need a tweener racket, and i'm sure you'd be better off with an 80$ new racket.
but if you're around the 4.0 + then this racket would be perfect. even a 3.5. i've switched around through like 6 different rackets til i found the k blade. it worked wonders for me. i'm a 5.0 now.
i don't play as serious tennis either, but IMO. the k blade would help you a lot. you has a lot of control but not as much power as the babolat..
i hope this helps.
do you meet lots of hot chicks playing tennis?
yes sir.
newer ones each and every year.
and they wear lesser and lesser clothes each year as well.
it's pretty much all WIN. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dafobbishon3
dafobbishon3
Texas
dafobbishon3
