CompuStar Pro P1W900FMR-G4 | RF-1WG4-900FM BNIB $110.00 Shipped
I can also suplly wiring info for your car PM ME
Up to 3000* feet of Range
This model uses 900MHz FM technology, the same as the two-way 900MHz FM systems. This compact remote features separate lock/unlock buttons, dual bright blue LEDs and extended range. Convenience and reliability are well worth the extra costs of this Pro one-way 900MHz system. This remote comes with a 2 year limited warranty.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 2 x One-Way remotes
View the manual for the P1W900FMR
Pro Remote Features
- Long range with 900MHz
- Separate lock/unlock
- Turbo Timer
- Shock Sensor on/off through remote
- Passive on/off through remote
- Valet mode on/off through remote
- Timer Start Mode
- Ignition Controlled Door Locks on/off through remote
- Secure Auxiliary Mode
- Uses 2 x CR2016 batteries
Pro Alarm Features | FT-4300A Pro Starter Features | FT-5200S Pro Alarm/Start Features | FT-5000AS
- Includes starter-kill relay
- Battery backup capable
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Optional Remote Paging System (unlock vehicle via pin)
- 2 auxiliary outputs
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output
- Upgradeable to two-way remote-vehicle paging - Includes anti-grind and optional starter-kill relay
- Cold and hot starting with temperature
- Programmable horn honk output
- Diesel compatible
- Manual transmission compatible
Pro Remote Features
- Turbo Timer
- Timer Start Mode
- Anti-Jacking mode
- Diesel compatible
