Sold FS: Clarion, Eclipse, MIT, Hertz, Rare Scans **Reduced Prices**
Here-I-Come
I have 2 Clarion APX-4241 4 channel amps up for grabs. One is BNIB the other is near mint.
$110 shipped in the US for the BNIB unit.
$95 shipped in the US for the Near Mint unit.
Specs:
Clarion U.S.A. | APX4241
Used one:
I have a Mint in Box set of Hertz 2w.100 passive crossovers. Crossover point is 2.8khz @ 12dbs. These are very nice passive unit, they feature hertz Best Sound Control Technology which is a listening point optimisation system. $50 shipped in the US.
Also have a mint set of Hertz ML20 passive units from the Hertz Mille 165 set.. These unit are very impressive. They also have Sound Control Technology which is a listening point optimisation. Crossover point is also 2.8khz @ 12dbs $65 shipped in the US.
I have one drivers side BNIB T-View 8" wide sunvisor monitor. It is light grey in color. $40 shipped in the US.
I have a pair of amazingly rare Scanspeak 13F wide-band drivers. There was only 5 pair ever made. The drivers are base of the Scanspeak 13M/8640 motor ( Scanspeak Classic 13M/8636-00, 4" Midrange from Madisound ), these use the Scan SD-1 (Symmetric Drive short circuiting). This is a very detail driver and in some cases sound better then the 12m. The pyramid cones both have very small dents in them but nothing crazy or any that would come close to effecting the sound. Said I would near sell but.....
Here is all the info I have on them:
voice coil is 14mm and is centered 60% in gap
Nominal excursion 5mm one way.
8 ohms
FS 100hz
Power handling is said to be 50 watts rms without highpass crossover. So add a high-pass filter and they will handle quite a bit more. I test them on DLS A3 and took the power like a champ.
Impedance is said to nearly flat from 100hz-15khz, so it a very easy load for amps to drive.
Efficiency: 82.7db
Sensitivity: 85db
200 shipped in the US. This price is way below what I paid for them
I have 5 units of the super rare MIT AutoTerminator Pro Speaker Articulation Modules some more items I said I would never sell.
These units are of direct origin from the Award winning MIT Oracle Technology. They where marketed for Auto Audio used, but can be used in either Home or Auto. These unit where available in 3 levels, Street units (entry level), Competition units (audiophile level) and the Cream of the crop Pro units ( Epert/on holds bore Level). What you see here are the PRO units!! These units had a retail value of $1200 for the pair. What I have are 2 High/mid units in chrome which where the production units. I also have 2 more High/mid units, but are in the prototype casing and lastly 1 Mid/low unit in the Prototype casing. That’s 5 units in total, that’s a whooping $3000 in modules.
$305 shipped in the US.
I have a near mint Eclipse ECD-415, the ECD are some of my favirote old school SQ units, these units where all about SQ and smooth and clean looks. No box or trim ring, but I do have the original manual. $115 shipped in the US.
Here are some specs for the unit.
Eclipse Security Network or ESN NOTE: not activated so no Security CD needed.
8 times oversampling digital filters & Dual 1 Bit D/A Convertors.
Output Impedance - 22 ohms
Output Level voltage - 2.7 volts
Tone Action - Bass +/- 10db @ 100hz - Treble +/- 10db @ 10khz
S/N Ratio - 94dbs
Total Harmonic Distoriton - .02% @ 1khz
Here-I-Come
Here-I-Come
Miami, FL
Jh8909
