I have an almost mint condition Z1200 ran at 1-ohm. It has the orange plates and the black X instead of the silver. It has been properly set with a DMM. Its never been abused. Is an under rated amp. Does close to 1400 at 1-ohm with proper electric.
I need $180 + shipping. It must go ASAP.
Specs and Pics:
1 Ohm Mono Power 1200 watts (Does closer to 1400@ 1ohm)
Frequency Response 10Hz - 40KHz
Signal/Noise Ratio >100dB
Damping Factor > 200 @ 100 Hz
Minimum THD
Channel Separation >65dB
Input Voltage 150mV - 8 Volt
Dimensions 19” x 10.75” x 2.4” (LxWxH)
Specs and Pics:
Minimum THD
