I bought this new and used it for probably 5 months or so. I now have a txa3004 and a smaller oldschool rockford amp for my tweeters. So I'm selling this to buy a new comp set. Its a two channel amp, I still have the box and remote knob.
4 Ohm RMS Power: 2 x 150 Watts @ 13.8 Volts
Under warranty until November 16, 2010 through audiosavings.
2 Ohm RMS Power: 2 x 300 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 1 x 600 Watts @ 13.8 Volts
Frequency Response: 20Hz - 30kHz
Damping Factor: >200 @ 100Hz
S/N Ratio: >100 db
Channel Seperation: >65dB
Minimum THD:
Dimensions: 17" x 9.2" x 2.12"
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=53056336&albumID=2982972&imageID=51811760
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=53056336&albumID=2982972&imageID=51811698
It was never mistreated and the stuff you see on the top is a little butyl rubber off some raamat that will come right off.
This will power a set of components wonderfully.
70 shipped sounds good to me. If interested PM me.
I've bought from dropbottommazda and sold to KickerRex .
For some reason the images aren't wanting to work besides in links, but the links work.
S/N Ratio: >100 db
Minimum THD:
