I have these 2 amps for sale. I just received them on Friday but have decided to go in a different direction. The TXA-3002 wasn't even taken out of the box and the DCA-1000d was taken out of the box just to look at it.
Cadence DCA-1000dhttp://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6014 I would like $300 shipped in the US
SPECIFICATIONS:
*4 Ohm RMS Power: 1 x 25 Watts @ 13.8 Volts
*2 Ohm RMS Power: 1 x 750 Watts @ 13.8 Volts
*1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
*2 Amps Bridged: 1 x 2000 Watts
*Frequency Response: 10Hz - 500Hz
*S/N Ratio: >100 db
*Damping Factor: >500 @ 100Hz
*Minimum THD:
*Input Voltage: 200 mV - 6 Volts
*Dimensions: 11" x 9.5" x 3.5"
FEATURES:
*High Speed Mosfet Power Supply
*Bi-Polar Japanese Sanken Output Devices
*Double Sided Copper Rail PCB Architecture
*24 dB Crossover Circuitry
*Low Pass Crossover: 35Hz - 250Hz
*Subsonic Filter: 10Hz - 50Hz
*Bass Boost Equalization: 0-18db @ 45Hz
*Lucite Encapsulated Large 2 and 4 Gauge Terminals
* Dash Board Bass Remote
*Dual-Amp Bridging for Double the Power @ 2 Ohms
*Master/Slave Control
*Adjustable Phase Control
*Soft Start Mute & Delay
*Tiffany Style RCA Line-In/Line-Out Jacks
*24db Crossover Roll Off
*Blue Edge-Lit Acrylic Side Panels and Light Bar
Cadence TXA-3002 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6097I would like $100 shipped in the US
Specifications:
# 4 Ohm RMS Power: 2 x 150 Watts @ 13.8 Volts
# 2 Ohm RMS Power: 2 x 300 Watts @ 13.8 Volts
# 4 Ohm Bridged RMS Power: 1 x 600 Watts @ 13.8 Volts
# Frequency Response: 20Hz - 30kHz
# Damping Factor: >200 @ 100Hz
# S/N Ratio: >100 db
# Channel Seperation: >65dB
# Minimum THD:
# Dimensions: 17" x 9.2" x 2.12"
Features:
# High Speed Mosfet Power Supply
# Studio Grade Bipolar Output Stage Transistors
# Fully Adjustable 18dB/Octave Crossover
# Fully Adjustable Bass and Treble EQ Controls
# Adjustable Input Gain 170mV-5V
# Ultra Reflective Chrome Top Cover
# 2 Ohm Stereo Stable
# 4 Ohm Mono Bridgeable
# Power and Protection LED Indicators
# Full IC Controlled Protection Circuitry
# Mute and Soft Delay Circuitry
# Lucite Encapsulated Terminals
Cadence TXA-3002 Cadence 2 Channel High Power 600 Watt Amplifier TXA3002 TXA 3002
I haven't made any deals on here but feedback can be seen here. http://www.softballfans.com/forums/showthread.php?t=148757&highlight=mikewohlwend
SPECIFICATIONS:
*S/N Ratio: >100 db
*Minimum THD:
FEATURES:
Specifications:
# Minimum THD:
Features:
