Sold Fs: Brand New Ma Audio Hk12x2 Cheap!
SPECS:
1500W RMS
3000W MAX
Sensitivity: 88.9dB @ 1w/1m
Mounting Depth 8"
Mounting Diameter 11"
Vented Box: 3.0 cu/ft
Port: 48 sq/in 14.5" Long
Sealed Box: 1.5-2.25 cu/ft
Dual 2 Ohm
Aluminum Round Wire Voice Coil
Hi-Temp Kapton Voice Coil Former
400 Oz. Double Stacked Strontium Magnets
Patented Thermo-Cooling Motor Structure
Bumped Back Plate for Max Excursion
High Roll Triple Layer Ribbed Surround
Double Layer Progressive Spiders
Dual Layer Pressed Carbon Fiber Cone
Ultra Strong Carbon Fiber Dust Cap
Rubber Sealant Gasket
T/S PARAMETERS:
FS (HZ) : 31.89
QMS: 5.701
QES: .360
QTS: .338
VAS(LITERS): 51.238
REVC(PARALLEL-OHMS) : 1
SPL @ 1WATT / 1 METER (DB) : 88.9
X-MAX LINEAR PEAK-PEAK(MM) : 70
LEVC AT 1K HZ (MH) : 1.059
jalverson
my face got jacked!
jalverson
Williamston, MI
Annnarbor84
