CONDITION: BRAND NEW IN BOX
$200 Shipped.
HC Series features:
High Current,Non-Regulated Power Supply
Double Sided PCB
Cooling Fan (Thermal Regulated)
24dB Active Slope Crossover
18db Variable Frequency Bass Boost
Variable Phase Shift(180 degrees)
VU Meters
Line Out
Protection Status Indicator
Specifications:
Bass Frequency Range: 45Hz to 90Hz
Bass Boost: 0 - 18db
Frequency Response: +- 1dB from 10Hz to 40KHz
Signal to Noise Ratio: > 100dB
Input Sensitivity: 100mV to 7V
Channel separation(AT IW): > 60dB
Damping Factor(ATIW / 50Hz): >240
Typical Current Draw At IDLE: 1.4Amps
Stereo Power
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
4 X 250 RMS @ 0.5 Ohm
Mono Power:
Bridged 2 X 180 RMS @ 4 Ohm
Bridged 300 RMS X 2 @ 2 Ohm
Bridged 500 X 2 RMS @ 1 Ohm
Recommended Fuse Size:
30A x 2
Dimensions:
11-1/2" X 2-1/2" X 17-3/4" (H x W x L)
$200 Shipped.
HC Series features:
Double Sided PCB
VU Meters
Line Out
Specifications:
Stereo Power
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
Mono Power:
30A x 2
Dimensions:
